How to Replay ros2 bags with changed Quality of Service
In this post, you will learn how to replay ros2 bags with changed Quality of Service (QoS) setting. You’ll discover how to set the QoS before recording the bag, and how to change the QoS when playing back the bag file.
Click here to copy the project. It would be copied to your cloud account at The Construct. That done, open the project using the Run button. This might take a few moments, please be patient.
Step 2: Start a simulation and the Quality of Service publisher
Open a web shell (1) and run the following commands to start a simulation:
export GAZEBO_RESOURCE_PATH=/home/user/ros2_ws/src/turtlebot/turtlebot3_simulations/turtlebot3_gazebo:${GAZEBO_RESOURCE_PATH}
export GAZEBO_MODEL_PATH=/home/user/ros2_ws/src/turtlebot/turtlebot3_simulations/turtlebot3_gazebo/models:${GAZEBO_MODEL_PATH}
You should see a simulation like this. If the robot does not show up, shutdown using Ctrl+C and run the above command again.
Now make the robot move by publishing to the /cmd_vel topic, in another web shell (2). You should see the robot move.
ros2 topic pub --once /cmd_vel geometry_msgs/msg/Twist "{linear: {x: 0.1, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 1.0}}"
Now start the QoS publisher in the same web shell (2) where you published to /cmd_vel. Note that we set the reliability to reliable. The QoS publisher publishes to the /robot_pose topic.
ros2 run qos_pose_publisher qos_pose_publisher -reliability reliable
Now let’s look at the reliability of the /robot_pose topic in a new web shell (3):
ros2 topic info /robot_pose --verbose
You should see something like this as part of the output:
QoS profile: Reliability: RELIABLE Durability: VOLATILE Lifespan: 9223372036854775807 nanoseconds Deadline: 9223372036854775807 nanoseconds Liveliness: AUTOMATIC Liveliness lease duration: 9223372036854775807 nanoseconds
Step 3: Record and play back a ros2 bag file of a topic
Now let’s record a ros2 bag file of a topic in web shell (3). We are using the /robot_pose topic.
ros2 bag record -o ros2bag_qos_as_published /robot_pose
Let it run for 5 seconds and then kill it, in web shell (3). You should have a new file created:
Now let’s play the ros2 bag. But before that kill the qos_pose_publisher node in web shell (2) by pressing Ctrl+C. In the same web shell (2), run the following command:
ros2 bag play ros2bag_qos_as_published
Now let’s examine the QoS of the /robot_pose topic (now being published to from the ros2 bag), in web shell (3):
You should see something like we saw before:
Step 4: Change the Quality of Service profile for ros2 bag playback
Create a profile file for ros2 bag playback. In web shell (3):
touch override.yaml
Open override.yaml in the code editor and paste in the following content:
/robot_pose:
history: keep_last
depth: 10
reliability: best_effort
durability: volatile
deadline:
# unspecified/infinity
sec: 0
nsec: 0
lifespan:
sec: 0
nsec: 0
liveliness: system_default
liveliness_lease_duration:
sec: 0
nsec: 0
avoid_ros_namespace_conventions: false
Now go to web shell (2), stop the ros2 bag playback (if it’s still running), and run the following command instead:
ros2 bag play --qos-profile-overrides-path override.yaml ros2bag_qos_as_published
Now, let’s see the quality of service of the /robot_pose topic. In web shell (3):
You should now see something similar to the following in the output:
QoS profile: Reliability: BEST_EFFORT Durability: VOLATILE Lifespan: 9223372036854775807 nanoseconds Deadline: 9223372036854775807 nanoseconds Liveliness: AUTOMATIC Liveliness lease duration: 9223372036854775807 nanoseconds
And that’s it! That’s how to replay ros2 bags with changed quality of service setting.
Step 5: Check your learning
- Do you understand how to set the QoS for the topic before recording a bag?
- Do you understand how to replay ros2 bags with changed quality of service setting?
(Extra) Step 6: Watch the video to understand how to create ros2 XML launch files
