[ROS Q&A] 146 – Command line argument passing in rosrun
[ROS Q&A] 146 - Command line argument passing in rosrun
Written by Marco Arruda
03/08/2018
In this video we are going to explore how to pass an argument through command line using rosrun.
It can be a bit confusing, but we are going to explain the difference of the return of the method depending of the type of the value you pass to the argument.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s call the project rosrun_param.
Step 2. Create package
We’ll create a package for our code with the roscpp and std_msgs dependency.
catkin_create_pkg my_pkg roscpp std_msgs
Under the my_pkg/src folder, create a my_pkg_node.cpp file with the code from the question.
#include <ros/ros.h>
#include <iostream>
using namespace std;
int main(int argc, char *argv[])
  std::string param;
  ros::init(argc, argv, "node_name");
  ros::NodeHandle nh("~");
  ROS_INFO("Got parameter : %s", param.c_str());
  if(nh.getParam("blue", param))
    cout << "blue" << endl;
  else if(nh.getParam("green", param))
    cout<< "green" << endl;
  else
    cout << "Don't run anything !! " << endl;
To compile the code, we have to modify the CMakeLists.txt file. Please uncomment the add_executable and target_link_libraries in the build part.
Then we can compile the code with
After compile, we can run the executable with
rosrun my_pkg my_pkg_node
The output is just don’t run anything because we didn’t pass any argument yet.
As an example, we can pass arguments like the following
rosrun my_pkg my_pkg_node _blue:=text
Then the output is blue.
However, the code doesn’t quite make sense. Let’s modify it.
#include <iostream>
  std::string param;
  nh.getParam("param", param)
  if(param.compare("blue")==0)
  else if(param.compare("green")==0)
  else
Now if you pass blue or green as arguments, it will print the color. If you pass something else, it will run nothing.
If you are interested in ROS and want to learn more about it, please check our ROS Basics C++ Course.
RELATED LINKS
ROS Development Studio (RDS)
Robot Ignite Academy
Alternatives to ROS
Alternatives to ROS
