In this video we are going to see how to set a sequence of goals for a manipulator robot, using the Python API in order to communicate with MoveIt!.
// RELATED LINKS
▸ Original questions: https://answers.ros.org/question/296994/how-to-set-a-sequence-of-goals-in-moveit/
▸ Robot Ignite Academy
▸ ROS Manipulation in 5 Days
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it moveit_qa.
Step 2. Use the moveit package
In this tutorial, we have already preconfigured the fetch robot and moveit package for it. If you want to know how to configure the moveit package, please check our ROS Manipulation in 5 days course. Then we create a file called execute_trajectories.py inside the fetch_moveit_config folder with the following content.
import sys
import copy
import moveit_commander
import moveit_msgs.msg
import geometry_msgs.msg
moveit_commander.roscpp_initialize(sys.argv)
rospy.init_node('move_group_python_interface_tutorial', anonymous=True)
robot = moveit_commander.RobotCommander()
scene = moveit_commander.PlanningSceneInterface()
group = moveit_commander.MoveGroupCommander("arm")
display_trajectory_publisher = rospy.Publisher('/move_group/display_planned_path', moveit_msgs.msg.DisplayTrajectory)
group_variable_values = group.get_current_joint_values()
group_variable_values[0] = 0
group_variable_values[1] = 0
group_variable_values[3] = -1.5
group_variable_values[5] = 1.5
group.set_joint_value_target(group_variable_values)
plan2 = group.plan()
group.go(wait=True)
rospy.sleep(5)
moveit_commander.roscpp_shutdown()
This script assigns target values to the joint 0, 1, 3, 5 and planning the trajectories to reach these goals.
Then we can launch the fetch robot simulation from Simulations->Fetch.
Before launching the file we just created, let’s use the following command to raise the robot to the fetch position
roslaunch fetch_gazebo_demo move_torso.launch
Then we have to launch the moveit package
roslaunch fetch_moveit_config fetch_planning_execution.launch
Finally, we can run our code(you’ll also need to give it permission before executing it)!
chmod +x execute_trajectories.py rosrun fetch_moveit_config execute_trajectories.py
The robot should move to the new position now. To execute sequence goal. We modified our script as follows.
... group.go(wait=true) group_variable_values[3] = 1.5 group.set_joint_value_target(group_variable_values) plan2 = group.plan() group.go(wait=true) group_variable_values[6] = 1.5 group.set_joint_value_target(group_variable_values) plan2 = group.plan() group.go(wait=true) group_variable_values[3] = 0 group_variable_values[5] = 0 group.set_joint_value_target(group_variable_values) plan2 = group.plan() group.go(wait=true) moveit_commander.roscpp.shutdown() ...
Then we run the script again. The robot should do several movements as we planned.
If you want to learn more about the motion planning with moveit package, please check our ROS Manipulation in 5 Days course.
![[ROS-Q&A]-138—How-to-set-a-sequence-of-goals-in-MoveIt-for-a-manipulator- [ROS-Q&A]-138---How-to-set-a-sequence-of-goals-in-MoveIt-for-a-manipulator-](https://www.theconstruct.ai/wp-content/uploads/2018/07/ROS-QA-138-How-to-set-a-sequence-of-goals-in-MoveIt-for-a-manipulator-.png)
