In this video, we are showing how to get the updated values of a parameter in runtime.
We can do any ROS development we want easily, without setting up environment locally in ROSDS and that’s the reason why we will use ROSDS for this tutorial. If you haven’t had an account yet. You can create one here for free now. After logging in, let’s begin our journey by clicking on the create new project and call it test_parameter_server.
Step 2. Create a new package for testing
Now, let’s create a new package for testing with the following command
cd ~/catkin_ws/src catkin_create_pkg testing_params roscpp
Then we create a new file called testing_params_node.cpp under /tesing_params/src with copying and pasting the following code.
#include "ros/ros.h"
#include <string>
ros::init(argc,argv,"my_node");
ros::NodeHandle nh;
ros::Rate rate(1);
std::string param1;
if(nh.getParam("param1",param1)) {
ROS_INFO("param ok!");
while(ros::ok) {
ROS_INFO("param1: [%s]" , param1.c_str());
ros::spinOnce();
rate.sleep();
To compile the code, we’ll uncomment these two parts in /testing_params/CMakeLists.txt
add_executable(${PROJECT_NAME}_node src/testing_params_node.cpp)
target_link_libraries(${PROJECT_NAME}_node
${catkin_LIBRARIES}
Then we run the following command under catkin_ws to compile the code.
After compile, you can run the node with rosrun testing_params testing params_node
NOTICE: We no longer run ROS master for you in the backend, please launch it with the command roscore in a new terminal.
You should get param1: [] as output since we haven’t assigned any value to it yet.
Step 3. Get the updated parameters at runtime
Let’s assign a value to param1 by typing this command in a new terminal.
rosparam set param1 "hello from terminal"
However, the output is still []. If we check it with the command rosparam get param1 , you can see the value is “hello from terminal”.
To update it, we have to add one line in the testing_params_node.cpp then compile and run again.
while(ros::ok){
nh.getParam("param1",param1); //Add this line
Now the output gets updated whenever you change the parameters.
You can also create a params.yaml file under /testing_params/ to assign the parameters. For example:
param1: "hello from file!"
Then you have to run rosparam load params.yaml to load the parameter.
Edit by Tony Huang
![[ROS Q&A] How to load ROS parameters in Runtime](https://www.theconstruct.ai/wp-content/uploads/2017/09/ROS-QA-How-to-load-ROS-parameters-in-Runtime.png)
kahit 1500 lang
plsee
give me diamond pls 1000000
ros_info
800 diamonds.
ros load
benedict
nfjhesfaje
f[segarg
gdrg
dsgds
grdsgr
dgrdgrdsrgdgrdsrg
r g
se
