Welcome to the ROS Q&A series again. In this post, we are going to answer and solve a question from a user on Gazebo Answers which asks how to launch a Parrot Drone simulation locally. The question can be found here.
- How to spawn a drone simulation in your local computer
List of resources referenced in this post
- The question on Gazebo Answers
- A live version of this post on YouTube: https://youtu.be/dwdVwwngMow
- The git repository that contains the drone_construct package, on branch kinetic-gazebo7.
- The spawn_robot_tools package used to spawn robots
- Ignition Math used by sjtu_drone
Downloading the required materials
Before downloading the repositories, let’s first create a catkin workspace for the parrot drone, which we will call parrot_ws. Let’s do that with the commands below:
mkdir -p ~/parrot_ws/src cd ~/parrot_ws/
Now we have the parrot_ws (parrot workspace). Let’s then download the required git repositories which contain the simulation:
cd ~/parrot_ws/src git clone --branch kinetic-gazebo7 https://bitbucket.org/theconstructcore/parrot_ardrone.git git clone https://bitbucket.org/theconstructcore/spawn_robot_tools.git
You should now have the folders parrot_ardrone and spawn_robot_tools on the ~/parrot_ws/src folder.
Installing ignition-math, used by sjtu_drone
Before compiling the packages we downloaded in the previous step, we will need to install the Ignition Math library, which is used by the sjtu_drone drone found on the parrot_ardrone repository we cloned previously.
We can install the Ignition Math library with the following commands:
sudo sh -c 'echo "deb http://packages.osrfoundation.org/gazebo/ubuntu-stable `lsb_release -cs` main" > /etc/apt/sources.list.d/gazebo-stable.list' wget http://packages.osrfoundation.org/gazebo.key -O - | sudo apt-key add - sudo apt-get update sudo apt-get install libignition-math4-dev -y
Now that we have the Ignition Math library installed, we can proceed to compile the packages in our workspace.
Compiling the drone package
Now that we have everything in place, we can compile our packages we downloaded previously.
IMPORTANT: it may happen that when compiling the package, catkin_make can’t find the ignition library, so we need to export the CXXFLAGS accordingly. In my local computer, the ignition library is found at /usr/include/ignition/math4, so to compile we use the following commands:
cd ~/parrot_ws export CXXFLAGS=-isystem\ /usr/include/ignition/math4 source /opt/ros/kinetic/setup.bash catkin_make
If everything worked as expected, great. If not, try removing the devel and build first with cd ~/parrot_ws/; rm -rf build/ devel/ and compile it again with the commands exemplified above.
If everything went ok, you should have something like:
root@79e5b2505ede:~/parrot_ws# export CXXFLAGS=-isystem\ /usr/include/ignition/math4 root@79e5b2505ede:~/parrot_ws# source /opt/ros/kinetic/setup.bash; catkin_make Base path: /root/parrot_ws Source space: /root/parrot_ws/src Build space: /root/parrot_ws/build Devel space: /root/parrot_ws/devel Install space: /root/parrot_ws/install #### #### Running command: "cmake /root/parrot_ws/src -DCATKIN_DEVEL_PREFIX=/root/parrot_ws/devel -DCMAKE_INSTALL_PREFIX=/root/parrot_ws/install -G Unix Makefiles" in "/root/parrot_ws/build" #### ... -- catkin 0.7.14 -- BUILD_SHARED_LIBS is on -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- ~~ traversing 6 packages in topological order: -- ~~ - custom_teleop -- ~~ - drone_demo -- ~~ - ardrone_as -- ~~ - sjtu_drone -- ~~ - spawn_robot_tools_pkg -- ~~ - drone_construct -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- +++ processing catkin package: 'custom_teleop' -- ==> add_subdirectory(parrot_ardrone/custom_teleop) -- +++ processing catkin package: 'drone_demo' -- ==> add_subdirectory(parrot_ardrone/drone_demo) -- +++ processing catkin package: 'ardrone_as' -- ==> add_subdirectory(parrot_ardrone/ardrone_as) -- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy -- Generating .msg files for action ardrone_as/Ardrone /root/parrot_ws/src/parrot_ardrone/ardrone_as/action/Ardrone.action Generating for action Ardrone -- ardrone_as: 7 messages, 0 services -- +++ processing catkin package: 'sjtu_drone' -- ==> add_subdirectory(parrot_ardrone/sjtu_drone) -- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy -- Boost version: 1.58.0 -- Found the following Boost libraries: -- thread -- signals -- system -- filesystem -- program_options -- regex -- iostreams -- date_time -- chrono -- atomic -- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so ... -- Generating done -- Build files have been written to: /root/parrot_ws/build #### #### Running command: "make -j4 -l4" in "/root/parrot_ws/build" #### Scanning dependencies of target _ardrone_as_generate_messages_check_deps_ArdroneActionFeedback Scanning dependencies of target _ardrone_as_generate_messages_check_deps_ArdroneGoal Scanning dependencies of target _ardrone_as_generate_messages_check_deps_ArdroneActionGoal Scanning dependencies of target _ardrone_as_generate_messages_check_deps_ArdroneResult [ 0%] Built target _ardrone_as_generate_messages_check_deps_ArdroneResult ... Scanning dependencies of target plugin_drone [ 1%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_ros_cam.dir/src/plugin_ros_cam.cpp.o [ 3%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_ros_imu.dir/src/plugin_ros_imu_native.cpp.o [ 5%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_drone.dir/src/plugin_drone.cpp.o [ 7%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_ros_sonar.dir/src/plugin_ros_sonar.cpp.o ... [ 9%] Linking CXX shared library /root/parrot_ws/src/parrot_ardrone/sjtu_drone/plugins/libplugin_ros_imu.so [ 11%] Linking CXX shared library /root/parrot_ws/src/parrot_ardrone/sjtu_drone/plugins/libplugin_ros_sonar.so [ 11%] Built target plugin_ros_sonar [ 13%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_ros_cam.dir/src/util_ros_cam.cpp.o [ 13%] Built target plugin_ros_imu Scanning dependencies of target plugin_ros_init [ 15%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_ros_init.dir/src/plugin_ros_init.cpp.o [ 17%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/plugin_drone.dir/src/pid_controller.cpp.o [ 19%] Linking CXX shared library /root/parrot_ws/src/parrot_ardrone/sjtu_drone/plugins/libplugin_drone.so [ 19%] Built target plugin_drone Scanning dependencies of target spawn_drone [ 21%] Building CXX object parrot_ardrone/sjtu_drone/CMakeFiles/spawn_drone.dir/src/spawn_drone.cpp.o ... [ 23%] Linking CXX executable /root/parrot_ws/src/parrot_ardrone/sjtu_drone/bin/spawn_drone [ 23%] Built target spawn_drone Scanning dependencies of target spawn_robot_tools_pkg_xacro_generated_to_devel_space_ [ 23%] Built target spawn_robot_tools_pkg_xacro_generated_to_devel_space_ Scanning dependencies of target ardrone_as_generate_messages_cpp [ 25%] Generating C++ code from ardrone_as/ArdroneFeedback.msg [ 27%] Generating C++ code from ardrone_as/ArdroneActionResult.msg [ 29%] Generating C++ code from ardrone_as/ArdroneAction.msg [ 31%] Generating C++ code from ardrone_as/ArdroneResult.msg [ 33%] Generating C++ code from ardrone_as/ArdroneActionGoal.msg [ 35%] Generating C++ code from ardrone_as/ArdroneGoal.msg [ 37%] Generating C++ code from ardrone_as/ArdroneActionFeedback.msg Scanning dependencies of target ardrone_as_generate_messages_py [ 37%] Built target ardrone_as_generate_messages_cpp [ 39%] Generating Python from MSG ardrone_as/ArdroneFeedback Scanning dependencies of target ardrone_as_generate_messages_nodejs [ 41%] Generating Javascript code from ardrone_as/ArdroneFeedback.msg [ 43%] Generating Javascript code from ardrone_as/ArdroneActionResult.msg [ 47%] Generating Javascript code from ardrone_as/ArdroneAction.msg [ 47%] Generating Python from MSG ardrone_as/ArdroneActionResult [ 49%] Generating Javascript code from ardrone_as/ArdroneResult.msg [ 50%] Generating Javascript code from ardrone_as/ArdroneActionGoal.msg [ 52%] Generating Python from MSG ardrone_as/ArdroneAction [ 54%] Generating Javascript code from ardrone_as/ArdroneGoal.msg [ 56%] Generating Javascript code from ardrone_as/ArdroneActionFeedback.msg [ 58%] Generating Python from MSG ardrone_as/ArdroneResult [ 58%] Built target ardrone_as_generate_messages_nodejs Scanning dependencies of target ardrone_as_generate_messages_eus [ 60%] Generating EusLisp code from ardrone_as/ArdroneFeedback.msg [ 62%] Generating EusLisp code from ardrone_as/ArdroneActionResult.msg [ 64%] Generating Python from MSG ardrone_as/ArdroneActionGoal [ 66%] Generating EusLisp code from ardrone_as/ArdroneAction.msg [ 68%] Generating Python from MSG ardrone_as/ArdroneGoal [ 70%] Generating EusLisp code from ardrone_as/ArdroneResult.msg [ 72%] Generating EusLisp code from ardrone_as/ArdroneActionGoal.msg [ 74%] Generating Python from MSG ardrone_as/ArdroneActionFeedback [ 76%] Generating EusLisp code from ardrone_as/ArdroneGoal.msg [ 78%] Generating EusLisp code from ardrone_as/ArdroneActionFeedback.msg [ 80%] Generating Python msg __init__.py for ardrone_as [ 82%] Generating EusLisp manifest code for ardrone_as [ 82%] Built target ardrone_as_generate_messages_py Scanning dependencies of target ardrone_as_generate_messages_lisp [ 84%] Generating Lisp code from ardrone_as/ArdroneFeedback.msg [ 86%] Generating Lisp code from ardrone_as/ArdroneActionResult.msg [ 88%] Generating Lisp code from ardrone_as/ArdroneAction.msg [ 90%] Generating Lisp code from ardrone_as/ArdroneResult.msg [ 92%] Generating Lisp code from ardrone_as/ArdroneActionGoal.msg [ 94%] Generating Lisp code from ardrone_as/ArdroneGoal.msg [ 96%] Generating Lisp code from ardrone_as/ArdroneActionFeedback.msg [ 96%] Built target ardrone_as_generate_messages_lisp [ 96%] Built target ardrone_as_generate_messages_eus Scanning dependencies of target ardrone_as_generate_messages [ 96%] Built target ardrone_as_generate_messages ... [ 98%] Linking CXX shared library /root/parrot_ws/src/parrot_ardrone/sjtu_drone/plugins/libplugin_ros_cam.so [ 98%] Built target plugin_ros_cam [100%] Linking CXX shared library /root/parrot_ws/src/parrot_ardrone/sjtu_drone/plugins/libplugin_ros_init.so [100%] Built target plugin_ros_init
Once the package is compiled, in every shell you need to source the parrot_ws so that ROS can find the compiled packages. In each shell you can run the commands below:
cd ~/parrot_ws/ source devel/setup.bash rospack profile
Launching the simulation
Now that you have everything in place, you should be able to launch the simulation with the command below:
source ~/parrot_ws/devel/setup.bash rosrun drone_construct start_simulation_localy.sh
That is it. You should now have something like the image below:
Moving the drone around
With the simulation running, you should now be able to make the robot take off, be able to move it and then make it land using the commands below:
rostopic pub /drone/takeoff std_msgs/Empty "{}"
rostopic pub /drone/land std_msgs/Empty "{}"
After running rosrun teleop_twist_keyboard teleop_twist_keyboard.py you can easily move the robot using the keyboard.
So that is the post for today. You can also find a live version of this post on our YouTube channel in the link below. Also, please consider subscribing to our channel if you liked the content and press the bell for a new video every day.
Related course:
- Interested to Learn More? PROGRAMMING DRONES WITH ROS (Python)
#drone #parrot #Simulation #Gazebo #Robot #rostutorials #Ubuntu
Post Edited by Miguel, Yuhong and Ruben.
Hello,
Can I mobe to real hardware after I simulate it, are there any significant changes parameters such as sensors and others? I use it for RL applications.
Thanks for the heads up on the Parrot drone simulation. The step-by-step instructions were handy for my DIY project. I would love to see the simulation of Ryze Tello drone listed here as well: https://mydeardrone.com/brands/dji/tello/
ı have a error like that:
serhat@serhat-VirtualBox:~$ rosrun drone_construct start_simulation_localy.sh
[rospack] Error: package ‘drone_construct’ not found
how can ı solve this problem ?
Thansk
I find this error too, did you solve it
use command
step .1: roscore (terminal 1)
step 2: source ~/parrot_ws/devel/setup.bash (terminal 2) # MOST IMPORTANT
step3: roslaunch drone_construct main.launch (terminal 2)
step4: source ~/parrot_ws/devel/setup.bash (terminal 3) # MOST IMPORTANT
step 5: roslaunch gazebo_ros empty_world.launch (terminal 3)
Hello, I have some issue that Gazebo don’t open, even though i did exactly what you have instructed
The result said that “process has finished cleanly” but still nothing else happened. Here is the result when i run your command “rosrun drone_construct start_simulation_localy.sh”
SUMMARY
PARAMETERS
* /rosdistro: kinetic
* /rosversion: 1.12.17
NODES
gazebo (sjtu_drone/start_gzserver)
sjtu_drone_spawn_urdf (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [15493]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 5984a742-4529-11eb-8939-54353083af3f
process[rosout-1]: started with pid [15506]
process[gazebo-2]: started with pid [15518]
process[sjtu_drone_spawn_urdf-3]: started with pid [15525]
SpawnModel script started
[INFO] [1608732948.108913]: Loading model XML from file
[INFO] [1608732948.109354]: Waiting for service /gazebo/spawn_sdf_model
[INFO] [1608732949.324783]: Calling service /gazebo/spawn_sdf_model
[INFO] [1608732949.792983]: Spawn status: SpawnModel: Successfully spawned entity
[sjtu_drone_spawn_urdf-3] process has finished cleanly
log file: /home/cuongchutan/.ros/log/5984a742-4529-11eb-8939-54353083af3f/sjtu_drone_spawn_urdf-3*.log
See this video on how to fix:
https://www.youtube.com/watch?v=dwdVwwngMow&feature=youtu.be
i was also facing same problem, my Gazeo did not opening but gave some time ,again and again watch video then get the solution.
Hi,I did what you said,but my gazebo just can not open,it just loading………what can i do?
Everything worked fine. However, I have one question. How can I respown multiple drones & publish data to each one of them individually.
I followed your instructions regarding including the model to the world and i did successfully respown two drones. However, when I publish data to the main one, the data gets published to both.
I’m using ROS Noetic and it nearly runs smoothly. Although I can make the drone to takeoff and land, I cannot control the drone with my keyboard. Everytime I run the command “rosrun teleop_twist_keyboard teleop_twist_keyboard.py”, it said: “[rospack] Error: package ‘teleop_twist_keyboard’ not found”.
Can you help me solve this pls!
Did you get the answer
Hi, I am able to get the drone to run locally. However, when I try to start the action server, I get the following error –
… logging to /home/amar/.ros/log/8c96c174-6297-11ec-ac95-b13131e1c3a6/roslaunch-amar-VirtualBox-3953.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
started roslaunch server http://localhost:36683/
SUMMARY
PARAMETERS
* /rosdistro: noetic
* /rosversion: 1.15.13
NODES
ardrone_as (ardrone_as/action_server.py)
RLException: Roslaunch got a 'No such file or directory' error while attempting to run:
/home/amar/parrot_ws/src/parrot_ardrone/ardrone_as/scripts/action_server.py __name:=ardrone_as __log:=/home/amar/.ros/log/8c96c174-6297-11ec-ac95-b13131e1c3a6/ardrone_as-1.log
Please make sure that all the executables in this command exist and have
executable permission. This is often caused by a bad launch-prefix.
The traceback for the exception was written to the log file
