ROS-based Robot
Turtlebot
TurtleBot is a low-cost, personal robot kit with open-source software.
With the TurtleBot robot simulation, you can perform the same tasks without the risk of damaging your real robot. Use the TurtleBot robot simulation to learn ROS and test robot algorithms. Once you have your code working in the simulation, directly execute your code using the real TurtleBot, with minimal or no changes required!
Works with
ROS 1
ROS 2
p
About TurtleBot
melonee-wise-fetch-robots-ros
TurtleBot was created at Willow Garage by Melonee Wise and Tully Foote in November 2010. With TurtleBot, you’ll be able to build a robot that can drive around your house, see in 3D, and have enough horsepower to create exciting applications.
For more information, we recommend an interview with TurtleBot creators, Tully Foote and Melonee Wise. TurtleBot Inventors Tell Us Everything About the Robot (IEEE Spectrum, By Evan Ackerman, 26 Mar 2013)
(source: TurtleBot)
    i
    Related courses
    i
    Related resources
    Infographic - A brief history of TurtleBot
    Tutorial - How to Navigate Autonomously with TurtleBot
    Tutorial - How to make TurtleBot rotate left and right?
    Tutorial - How to add a rotating join to Kinect in Turtlebot
    https://youtu.be/Y5K4gF2teIA
    Check the full tutorial
    Tutorial - Use OpenAI_ROS with TurtleBot2 Step by Step
    Tutorial - How to navigate while avoiding obstacles
    Tutorial - OpenAI Gym For ROS based Robots 101. Gazebo Simulator
    Tutorial - How to Move a Robot to a Certain Point Using Twist
    Tutorial - How to launch multiple robots in Gazebo simulator?
    Tutorial - How to check the distance to an obstacle using a laser
