We Make Your Robots Easy-to-Access for Over 100k ROS Developers
We help you market & distribute your robots to the world’s largest ROS developer community
3 Easy Steps for Your Robot Users
1) Unpack the robot
Your customer get the robot out of the box
2) Connect to WiFi
Use your procedure to connect the robot to wifi/cable
3) Use the Activation Code
Type in the activation code on The Construct. Then the robot is ready to be controlled by your customer.
2 Easy Steps for You
Install the one-line of code server on the robot
By executing a single line of code you prepare the robot for your customer
Send automatic email to the customer
This email contains your customer’s activation code and out-of-the-box running examples.
Your Robots are Ready for the World’s Largest ROS Developer Community
Your next customer is here. The Construct is the world’s largest platform for ROS Developers to easily use ROS online — powerful and flexible, simplifying access to ROS robots.
ROS user visits per week
Active ROS Developers
Universities & Companies
Simplify Your After-Sales Service with Better Experience, Less Manpower
Skip the initial setup. We make your robot programmable in ROS out of the box. Your customers can start using your robot right out of the box.
Easily Enter the ROS Market with Your Robots
All ROS distributions are ready to use online for your robots. No installation is required. Work on any type of computer.
We Only Partner with the Best
Manufacturers already on our platform
"An amazing platform, and so easy to use by ROS Developers at all levels and anywhere in the world."
– Radhika Nagpal
Professor of Computer Science at Harvard University
And it’s free for you and your customer.
Become a partner today!
